GaryD1971 Posted April 8, 2019 Posted April 8, 2019 (edited) Hi all. I'm looking for a speed sensor for an electronic speedo if anyone has one. Hall effect if possible. Many thanks. Edited April 8, 2019 by GaryD1971 Spelling mistake
Kingster Posted April 8, 2019 Posted April 8, 2019 I bought one like this for a few quid. Works perfectly!
GaryD1971 Posted April 8, 2019 Author Posted April 8, 2019 5 hours ago, Chris King - Webmaster and Joint North East AO said: I bought one like this for a few quid. Works perfectly! Wow! That's cheap! Thanks Chris. I'll order one of those. Did it connect up easily? I assume the 3 wires are ground, signal and 12v supply which would match up to the input wire on my racetech speedo.
Kingster Posted April 9, 2019 Posted April 9, 2019 7 hours ago, GaryD1971 said: Wow! That's cheap! Thanks Chris. I'll order one of those. Did it connect up easily? I assume the 3 wires are ground, signal and 12v supply which would match up to the input wire on my racetech speedo. Yes, 3 wires are as you say. For the price it was worth a punt - not sure if that's the exact same one I got a year or two back, but looks identical and the specs appear to match. I think I paid £3.99 delivered - and as I said, works perfectly. 1
GaryD1971 Posted April 9, 2019 Author Posted April 9, 2019 Does it need a magnet or does it work off the head of a bolt? I've seen some that come with a magnet and others that don't. They all seem to be about the same price range.
Kingster Posted April 9, 2019 Posted April 9, 2019 You should get one with no magnet required. Mine doesn’t need one.
Dave Eastwood (Gadgetman) Posted April 9, 2019 Posted April 9, 2019 Interesting, Hall effect sensors are normally used with magnets aren’t they? I thought it was VR sensors that simply detected a ferrous target, like a bolt head.
Kingster Posted April 9, 2019 Posted April 9, 2019 Maybe using the wrong term - but I thought Hall effect was just using ferrous - pretty sure mine was call a Hall effect sensor and has no magnet. The one I had before used a magnet and was 2 wire.
Dave Eastwood (Gadgetman) Posted April 9, 2019 Posted April 9, 2019 It’s true, three wire types don’t usually need magnets!
GaryD1971 Posted April 9, 2019 Author Posted April 9, 2019 Thanks chaps. I'm going to order one with 3 wires and see what happens. Haven't exactly lost a lot if it doesn't work.
David Oxfordshire Posted April 10, 2019 Posted April 10, 2019 I have the Honeywell one as recommended by SCS, works a treat GT101 is the part number i think. Just needs your nuts going past the end
GaryD1971 Posted April 10, 2019 Author Posted April 10, 2019 1 hour ago, David_Thame said: I have the Honeywell one as recommended by SCS, works a treat GT101 is the part number i think. Just needs your nuts going past the end have to be careful doing that....
Pintodavid Posted May 4, 2019 Posted May 4, 2019 I have one of those sensors, it three wire but Hall effect not induction, you will need a magnet. Hope this helps. 1
GaryD1971 Posted May 9, 2019 Author Posted May 9, 2019 On 08/04/2019 at 16:43, Chris King - Webmaster and Joint North East AO said: I bought one like this for a few quid. Works perfectly! I bought one similar to this Chris, and it works really well. I went for the induction type as opposed to the hall effect (they may both be the same?). Cheap as chips off fleabay and easy to wire in! Thanks for the recommendation.
