C20xe superlite flywheel, 7 1/4" race clutch and plates. - SOLD
Helix 7 1/4" clutch, 2 x cerametallic plates and Turbosport flywheel. 327ft lb "Green" spring in the cover.
Commonly used in rally cars these plates allow more slip and are therefore easier to control than sintered plates.
The sprung plate measures 6.93mm (range is 7.3mm - 6.3mm) so not half worn yet. The sprung centre makes this clutch OK to use on the road. It's not a road clutch, it's a race clutch but in my experience you can use it on the road in small doses. It would very soon p**s you off in traffic though.
The solid plate I found to be OK around the paddock but I would recommend it for any sort of road work really. It measures 7.04mm (range is 7.3mm - 6.3mm).
The flywheel has just been re-faced and weighs in at 2.4kg.
This lot would cost just short of £1k to buy new.
£400 plus carriage of your choice.
