Harness, TRS
Matt Hillam (Fatbloke) - Herts Beds & Bucks AO
6 point FIA TRS Harness
Loop type upper fixing, bolt in lap and crutch straps
75mm shoulder and lap straps, 50mm crutch straps
Used for a couple of events only so very good condition, dated 2017.
Collection available from Luton, a WSCC Speed Series round or British Sprint round.
£50 + delivery.
Matt
zero 7908 162618
I don’t suppose you have a matching one tucked away?
Only the Sabelt one also advertised here, can do a deal on the two if that helps?
Matt
Thanks Matt but I was after both the same, just out of interest does the 6 point require two extra mounting points or do they attach to the bottom fixings?
I've always used 6 different mounting points but you may be able to find a way of using the existing 4 to fit the 6 harness points to.
Matt
Thanks Matt, could it be used as a 4point without the crotch straps?
Yes.
Each side of the crutch strap passes through the steel loop fitted to the lap strap and is retained by the shoulder strap tag - as per the picture.
Matt
In my Westfield the crutch straps use the same anchor points as the waist belts
  • 2 weeks later...
Now sold, thanks for looking.
Change of plans - for sale again.
