John Loudon - Sponsorship Liaison Posted February 17, 2019 Posted February 17, 2019 Lithium 12v battery. Weighs 0.9kg. Was new in 2017. Removed from my car as no longer MSA compliant. 240 cold cranking amps. Charge indicator and test button on top. Full working order. Size = L 150mm x H 95mm x W 85mm £55 posted John O797I 576848
Rob the Red Top Posted February 19, 2019 Posted February 19, 2019 What engine were you running with this? Cheers Rob
John Loudon - Sponsorship Liaison Posted February 19, 2019 Author Posted February 19, 2019 19 minutes ago, Rob the Red Top said: What engine were you running with this? Cheers Rob Puma 1700 with 11.5:1 compression. I did use a slave battery to give an additional boost on first start up on really cold days but after that it was fine for the rest of the day.
Rob the Red Top Posted February 19, 2019 Posted February 19, 2019 16 minutes ago, John said: Puma 1700 with 11.5:1 compression. I did use a slave battery to give an additional boost on first start up on really cold days but after that it was fine for the rest of the day. Might be a bit much for my engine... Running a red top with 12.5 to 1 compression and lights...
