4 x 15"Team dynamics wheeels with 195/50/15 Toyo Proxes
Recently taken off my westfield I have 4 x 15" x 8J Team dynamics motor sport wheels in reasonable condition, they are fitted with 195/50/15 toyo proxes with plenty of tread.
Looking for £400 but would take a sensible offer give me a call on 0791 7563 290 .
What offset and PCD are they (guessing 4x108 ?) ?
PCD is 108 and the offset if I have it right is 40mm   calc =   50% of 200mm (Wheel width) = 100mm distance from rear of rim to hub plate 140mm = 40mm offset I think.
regards
Gary
Thanks but unfortunately I'm after a set to fit Mazda PCD 4x100....
Peter.
HI Guys,
Mistake made in advert the rim is a 7J (just found the stamp on the rim) and the offset is 35mm, the fitted my westfield without spacers.  .
regards
Gary
  • 1 month later...
Hi
Are these still available ?
I have not been online here for some time... so have only just seen this.
cheers
2 hours ago, Kent Westfield said:
Hi
cheers
Original post is by a member who no longer has access to the forum I’m afraid.
Ok thanks
