Clarke CFC100 Folding 1 ton engine crane & Load leveller
Clarke CFC100 Folding 1 ton engine crane and load leveller
Crane is about 4-5 years old is in great condition and has just had all the seals in both jack heads pump replaced. Load leveller is rated for 900kg. I had my zetec in and out of my chassis probably 4 or 5 times with this package.
Crane is currently £197 from machine mart and load leveller was £30
Currently located at my work in Sheffield (S9) or collection from my home in Wetherby (Ls22)
£100 collected
  • 5 weeks later...
Any interest before I chuck this on eBay ?
No, but I’d like to know how to change the seals? Good luck with sale...
They are extremely simple bits of kit.
Use a blunt pick to remove the old seals - replace seals hey presto !
Honestly if you can build a westy you have no worries with changing the seals.
If yours is like mine with two pump heads you need to order 2 seal kits not the 1 that machine mart will tell you to !
Hi.
would you be interested in selling the load leveller on its own.
No worries if not.
Ian
I'd like to sell it as a package. If that changes I will let you know.
No Problem at all
Good luck and get a free bump
Hi,
if you could do it for £90 I can collect on Monday afternoon next week??
Yes no problem.
where would you like to collect from ?
Mark
Sheffield S9 if you pm the address and I will let you know the time probably around 3.30 if that is OK?
No problem !
