Mounting brackets for HP fuel pump and filter
I have both an HP fuel pump and filter to fit but don’t currently have any mounting brackets for them. Pump and filter are as follows:
Large rubber lined P-clips work well for these, as a suggestion
Can you not make your own?
Between the red and black circle is rubber, give's it a bit of a cushion like. Use some 1mm alloy and wrap it round the pump with a couple of bends on it. Black bit is a bit of mild steel to spread the clamping force. Use 2 M6 through the chassis.
o3OuJP1kt0SMBcJsCEJ942VmEq-7G_K31ROPL47O2C-c_lhCqShMUTIeyREpaGmUcQDyViDT5phyx7971F5tvQBYeVHJU5CF2SJD5KTiz534y1A97FmWWH6_t0Lb-7AARSjVXg-1ubqjnKXhv90u8Ji3t15gSKvbHEzcXnx4ExDZLgj_auG4HDSiVGxEJ6o8FCYb5XeZMaL5XeFkOm2r45ImfCJ6MyYC1Q-0ur-w9LaB-6qkBidWfRCFeYxG_m8yW75lvXK_QatRMyIhn7NumTtMWxUDHVPacRzybqyj3X-GllZ87_futKYO3NA6vvNbT4AENwxfwqS7nIvds6ndet9TXAnmToZHKPGR6wpLbo15xT-itiKOEFt1I_OZMPG17QPpxHgFzKfudsb1J1JGK5a-VITwgn8sEKeHkuuga8sh1wrYT0iX7sMOceDxXhwSXxeKN0MG1f061WN8DhXSLh4sNecJjPYs6p0VDDK2DBHdfXI6SzH2tXXJX32lswLj7CuqH9Ng_N3pQxRPtBmHHhTkzD963PNgVeAutT0hV2SuT-1Sy3kcee6ZtBsxsqb3fwxRjisan_lKaLFoouAxWqNmiyEw1-0wxy2w2pyGDnwUa_hTXesbEunXaZfOE28LM1sEuPsL4hr_oj5Eivlx8sxPKQ=w1057-h791-no
