Fireblade engine parts
893cc Fireblade engine parts for sale, from a '93 bike but should fit all 893's and some bits will probably fit a 919 too:
Crank, rods and pistons - good condition, bearing faces look fine - £120
Timing end cover - £15
Alternator End cover - £15
Oil pump - £25
Water pump £25
Clutch cover & clutch arm - £20
Cam cover inc gasket and bolts - £15
Cam chain tensioner - £10
Oil cooler (the bit between the filter and the engine) - £15
All plus P&P - should be no more than about £12-14 for the heavy bits, and only a few quid for the smaller bits
Or everything for £150
Contact enginebits@locostfireblade.co.uk or ed@westicles.net for info.
I'll take the:
Complete head inc valves, cams and chains - the head is bit grubby but would be ideal for porting - £40
Sump pan and oil pickup - £25
Block water outlet casing (under the exhaust - £40 from Honda! ) - £10
PM/email your address and the check is in the post or I may come and collect.
JC
List updated to reflect sold parts, and "Buy it all for" price reduced accordingly!
Cheers,
Al.
