250bhp Supercharged Clio 172 Track Car
Clio 172 - Supercharged
MOT till June 2019
Currently Sorn.
Engine
- 182 Engine, rocker cover painted white, block painted black.
- Rotrex Supercharger kit with associated boost pipes.
- Gen90 ECU
- Toyosport Intercooler
- Custom Roose Motorsport hoses
- Samco Coolant hose kit
- Magnecor Leads
- Mocal Oil Cooler
- Mocal Catch Tank
- ARP Rod Bolts
- K-Tec / Vibratec Solid Engine Mounts
- Matched Inlets
- K-Tec 3.5" Recessed Supersports exhaust
- Megane Injectors
- 102k miles, new cambelt, dephaser, aux belt, megane keyweyed pulley and megane crank bolt fitted and timed by Dan@SJM
- Powdercoated inlets, fuel rail guard, engine mount and brackets
- Bosch S4 battery
- Air con delete
- Nimbus heatshield
- Mapped by RS Tuning, Rolling Roaded at 248.7bhp and 220 ft lb.
- 105,800 miles
Transmission
New Gearbox
- Gripper LS Diff
- PMS Race Shifter / Gear linkage
Handling
- AST 5100 Coilovers with custom spring rates
- Northloopcup / BIGASH Roll Centre Kit
- Whiteline ARB
- Eibach Hubcentric Spacers (16mm front, 5mm rear)
- PMS Solid Top Mounts and Strut Brace
- Eibach Camber bolts
- -2.5 deg camber at the front, 10 mins toe. -1 deg camber at rear
- PMS Stud and Nut kit fitted
- 15 Speedline Williams wheels with Dunlop Direzza 03g tyres
- Cup wishbones fitted
Braking
- Brembo 4 pots (Megane 225)
- Custom HEL braided lines
- Custom Chris Powell Brembo brake brackets
- ABS delete (incl. Loom), full Cup brake lines and MC setup fitted
- Ferodo DS1.1s, Ferodo DS2500s rear.
- Brembo grooved HCs (Front)
- Renault OEM Discs (Rear)
- ATE Super Blue Racing brake fluid
- Fog lights removed and no arch liners
- brake ducts
Interior
- 2x Sparco Evo 3 Bucket Seats
- OMP Subframes
- OMP 3" Harnesses
- Custom Oreca / Renaultsport 330mm Steering Wheel
- OMP boss
- 6 point Roll Cage
- K-Tec Rear Boot Mat
- Renaultsport Front Mats
- Sony CD Player with Ipod Connector
- White Dash Strips & Gear Insert
- Alcantara Handbrake Cover
- Rear Strut Brace
Exterior
 Cup Splitter
- Trophy Spoiler
- Renault Sport 197 Badge
- Porsche 'Bee Sting' Aerial
- Lockable Aerocatches
It will come with a spare set of black 15" speedline williams wheels with Dunlop Direzza 03g tyres (plenty of tread) and the standard set of 172 wheels with some pirelli p-zeros (although these are a bit "time expired").
£6995
  • Like 3
I think the site you’ve hosted the photos on may need you to be a member to view them...
Ah b******* 1 sec.
