Any heating engineers out there?
Do we have any heating engineers that can identify this brand of valve?  Getting a like for like will save changing pipes / connections.
Thanks in advance.
Caleffi part number 314430 give advanced water a call they should have them in stock 01386 760066.
Is it passing? Ie dripping from the pressure relief pipe.
Thank you very much, yes it is leaking.  The water bill being several times prompted a search for leaks.
Are you topping the pressure up on your heating system?
No topping up as everything seemed to be working ok.  On trying to top up all it did was leak back past the valve.
