Rims for Slicks
Wanted 13" x 10" & 13" x 8"
Very interested to seeing what you have, thanks David
  • 2 weeks later...
I have 2 Image 13"X 8" minlight type wheels as new used only once at a sprint.
£110 each.
Hi, do you know the backspace dimension and is it possible to measure the diameter of the inner rim as I don't have much room over the caliper.  Can you give me a link to the wheel on the Image site or a photo, thanks David
Hi David. The 13"x8""Image wheels measure.
Back Space 125mm
Inner Dia 320mm
The rims were fitted to the front of my Westfield you can ring me on 07803957602
Hope this helps.
Chris.
Hi Chris
Will try and phone tomorrow lunchtime as need to go out this evening,
A couple more quick questions,
Are the tyres Avon ZZS, what size are they and do the come with the rims ?
Do you have more than two rims for sale ?
The reason I ask is I need to find at least four rims and only buying two from you means I would then have to buy two new 10" from Image to match which would bring the total cost to quite a lot or if you had four rims for sale it might be possible for me to then get Image to swap the outer rim on two off them to give me what I am after.
Regards David
