Wirral and North Wales Sunday run.
Tudor Rose, 4th November, heading into Wales to find a breakfast.
Meet at 9 for a 9.30 start.
Tudor Rose is on the A540 at Two Mills, near the A550 junction.
see you there
Do you know where you are meeting for breakfast?
As long as it’s dry I will see you at the Tudor rose
kevin
Ponderosa for a change. Might be a bit cooler up there so don't forget the thermals.
Farmer John is meeting his grandson there, are you coming Nic? You know you want to.
kevin
Wales is green and there's a reason for that. Had more soakings there than a blanched potato. Forecast is good, fingers crossed, it's worth it for the breakfast at the Ponderosa.
Ok you should be a salesman ....and breakfast on me
It's falling to bits.
Too much front wing?
  • Sad 1
Not exactly sure what it is, but looks like the O/S bracket has sheared?
It looks like its designed to channel air into the rear diffuser for the ground effects, either way you broke it :laugh:
John that explains the noise from your car when you was alone side of me on the 55,  also should we not have turned right at that cross road ????
Cracking run out today
Jeff
Jeff
Crossroad? What crossroad? I just follow you Jeff.
Could have gone either way, Ruthin is a nice run. We could have gone over the top, Moel Fammau is always good.
  • 2 weeks later...
Hi all
im located Chester and haven’t met up or been out enough in my westy since becoming a member or my purchase in Feb!
I need i day out as I’m stupidly trying to sell as it’s just sat in the garage and I know I’ll regret letting it go
#helpdavegetoutwiththelocalcrew
hope to meet you all soon and get out so I snap out of this regreatable stage :-)
thanks
Dave
07776215879
