Rob the Red Top Posted October 9, 2018 Posted October 9, 2018 Hi, Changing my stock Manta gearbox (G240) for a straight cut type 9 on my SE Narrow body and I need a dif. The rear has a ford live axel. I expect I will have to have shortened as I've fitted an XE so the location of the engine is unlikely to be stock. Thanks Rob
Steve (sdh2903) Posted October 9, 2018 Posted October 9, 2018 Can highly recommend Dave mac props for any modification or a new prop making. They are competitive on price too. http://davemacprops.co.uk
jeff oakley Posted October 11, 2018 Posted October 11, 2018 I have a prop but it is pretty short. You need to measure from the diff flange to the back nose of the gearbox. If you let me have that I will see if this would fit. You also need to measure the diff flange as it should be the small one off a Mk1 escort.
