**SOLD** Westfield SE Widebody – Aero Race Chassis – 2.0 Duratec – 306bhp - 198lb/ft
£19995
Road Registered. V5 Present.
Power to weight = 570bhp/tonne
Engine
Ford 2.0 Duratec
Built in 2016 by Premier Race Engines, Brackley and Northampton Motorsport
New short block from Ford UK
Forged Arrow Steel Crank
Forged Arrow Connecting Rods
SBD Slipper Forged Pistons
Ultimate performance head with over sized valves - Flows enough for 330bhp if ever fitted to a 2.5.
SBD 300bhp specification cam shafts
440cc Injectors
Up-rated valve train - Solid lifters, shims, guides and valves. 9500rpm capable head.
Jenvey 50mm throttle bodies
Dry sumped using Titan alloy sump, pump (2 x scavenge, 1 x pressure)
Pace alloy tower tank
Air to Oil oil cooler
55mm Coolex Alloy Radiator
Omex 600 ECU
All rotating and reciprocating parts were balanced by Premier Race Engines
The engine was re mapped by Northampton Motorsport in May 2017 and produced 306bhp @ 8700rpm and 198lb/ft @ 5200rpm.
The engine has done 8 hillclimbs, 1 track day, and a few road miles since build. (18 hours running time)
Original engine build cost was £26k.
Engine was purchased by myself in March 2018 from the person who commissioned it and was fitted to this chassis in June 2018.
Exhaust
Custom CSK Race exhausts 4-2-1.
Built to exact SBD specs for £1400 in June 2018.
Drive train
Quaife all alloy 5 speed Heavy duty Type 9
Titan alloy bell housing
Straight cut, close ratio 2.04, 1.54, 1.21, 1.0, 0.87
SBD super lightweight flywheel and twin plate ‘Super Clutch’ clutch
New Hydraulic clutch release system
Gearbox positioned to avoid need for selector extension
Rebuilt by Brian Hill at BGH Geartech and has done 7 events since then
Final Drive
English Axle with rare 4.4:1 CWP on a Quaife ATB limited slip differential – assembled by Brian Hill
Suspension
Westfield Aerorace with AVO dampers all round
All joints are poly-bushed, and dampers are rose jointed
Alloy uprights at front
Front adjustable anti roll bar
Front dampers rebuilt by AVO in spring 2015
Brand new Mini-lites with one track day old Yokohoma AO48R’s
Brakes
Factory fit floor mounted adjustable bias brakes
Race Leda four pot alloy callipers with Hawk ferro-carbon pads
Standard drums at rear
Braided hoses all round
Chassis
Westfield race chassis (i.e. additional bracing, but thinner tube, compared to ‘road’ chassis)
Chassis manufactured in 1999 (so no need for a catalytic converter under MSA rules)
All alloy panels were etch primed prior to painting, and are bonded using PRC (aircraft panel sealant) as well as riveted
Alloy front uprights
Bodywork
New lightweight ZK bodywork with V8 bonnet for engine clearance in August 2018.
Playskool carbon aeroscreen, dash, rear deck and glass fibre ‘diffuser’
Carbon NV arches
Interior
Dash2 Pro with GPS speed reading, internal logging and all UK tracks pre loaded.
Playskool glassfibre seats
Carbon NV Dash
Safety
Lifeline plumbed-in extinguisher
Driver’s 6 point FIA harness (In date)
Passenger’s 4 point Willans harness (Not in date)
1kg LiPo battery with cut off switch
Caged – full FIA race spec cage
History
The car was SVA’d when build was completed in 2001, and registered on a 1975 age related plate as a consequence of having demonstrable provenance to a donor Ford Escort.
The car remains road registered and can be tax’d and MOT’d.
Tax is free due to historic status.
The car was converted to a 200bhp Rover K series in 2004 before competing.
The car was then converted to a 306bhp Duratec in 2018.
It has done somewhere around 4,000 miles in total.
The car has been sprinted and hill climbed and is believed fully legal for RAC MSA approved circuit racing and speed events in UK.
The car is currently sorn with no MOT but can easily be MOT'd if the buyer wants as all the lights etc are present and working.
Can be delivered anywhere in the UK.
Anyone know where the drooling emoji is? :p
:suspect:
11 hours ago, marcusb said:
:suspect:
You should see the invoices, its enough to make you weep. The bill from Arrow for just the crank and the rods was over £5k before vat!
I could believe it. Big power tuning on NA engines has always been hugely expensive. I don’t think most realise just how much! Especially from one of the top engine builders.
I was quite amazed too. Getting a 2.0 Duratec to 250bhp isn't too bad. Those extra 50bhp really cost you a lot.
Yep, getting the old XE’s - a really tunable engine, though ultimately, not quite as capable as the Duratec of really big figures, would take around the £10/12k mark to around 250 ish bhp, but then to try and get up to that 300 bhp mark... tbh, I never dared to ask, but not just a few grand more, that’s for sure!
Sorry to drag a bit off topic but is that a standard westfield v8 bonnet? It just looks like a bigger scoop?
Thats not standard v8 bonnet!
  • 2 weeks later...
PROVISIONALLY SOLD
Sold!
Well done!
Hope whoever bought it does NOT do the speed series next year!!! :(:getmecoat::cry:
  • Haha 1
It’s going to be racing with 600bhp Evo’s in the CCRC GT series next year!
Phew! All the best with that:yes::d
