SEight 5.1 V8 - SALE agreed
SALE NOW AGREED
After much deliberation I have decided its time to move on to something else, only real reason for sale is that my wife and I have recently got back together and as we have an 11 year old son I want a second car that we can all enjoy at the same time.
I bought the car in Feb 2017 and have since lavished huge amounts of time, effort and not a little money taking a really nice car and making it even better (I hope)
The car attracts a huge amount of attention and has never ceased to put a smile on my face, it has been virtually faultless, a bad indicator earth and a failed clutch slave cylinder being the only issues I have encountered.
Will come with a massive folder full of invoices dating back to its original build up to date and is a car that really needs to be seen to be appreciated.
Car is based in Telford, has MOT until end of Feb 19 - last one passed with zero advisories.
I would welcome any inspection / viewing and believe the first person to express serious interest will buy it - its a very special car but my family is more special to me.
Spec is below:
Registered – 2004
Current mileage – 13,000
Over 130 invoices totalling in excess of £30k build costs (excluding consumables)
General / Bodywork
Westfield widebody with FW (Featherweight) panels
Weight – approx. 670kg
Carbon fibre  dash, boot panel and rear arch protectors
Carbon NV aeroscreen and front wings
Westermann Motorsport carbon fibre half doors
Rose jointed RAC roll bar
Interior
Intatrim Stoneleigh GT seats with 2 stage heating
Scroth FIA approved harnesses
Carbon Mick carbonfibre chassis rail protectors
Instrumentation
Stack ST8130 Digidash Plus with full parameter recording and lap timing
Engine
5.1 V8 built by V8 Developments
330bhp @ 5300rpm
380 lb ft torque from 2200-4500rpm
Redlined at 6300 rpm
Lightened flywheel
Fully balanced
Vernier timing chain set
Big valve heads and race cams
Solid lifters
Jenvey throttle bodies with ITG filters
3 stage John Eales dry sump
Run on Millers CF 10w60 NT+ oil
Aeroquip fittings throughout
Bespoke long-range foam filled fuel tank
DTA 8 PRO programmable ECU with Launch and Traction control
Bespoke high flow radiator by Brise Fabrications
Electric pull fans controlled by ECU
Samco silicone hoses
Bespoke stainless steel exhaust and manifolds designed to meet strictest track sound test limits
Oil temp never usually goes above 100 degrees
Water temp never above 90 degrees
Has used no oil or water in my ownership
Transmission
R380 gearbox
Ford Sierra 7” diff with ZF plated LSD 3.62 ratio
Steering / Suspension
Specifications for suspension and set-up development by head of Audi Chassis Dynamics (UK)
Nitron dampers, dyno’d and matched to springs
Image 3 piece billet 15x7” / Nankang NS-2R 205/50/15 fitted at 12,500 miles
BG quick release hub
Quick rack (2.1 turns lock to lock) with stops
Brakes
Hi Spec Ultralight 4 pot front calipers with drilled / vented discs
Sierra rear calipers with drilled / vented discs
If you type in "Westfield SEight 5.1" in to YouTube there are a number of videos where you can see and hear this wonderful car
I might of missed it but can't see a price. Great looking car
Price is £14,500 - based very much on what other V8s have sold for in the last year and aligned to the massive spec of mine
Lovely looking car.  GLWTS
