MT-75 & Type 9 Chassis
Could be a daft question but what is the difference in the above chassis or are they the same. ~?
:durr:  :blush:
There are two types of chassis, a wide transmission tunnel, and a narrow tunnel. The wide option is used to accomodate the MT75 box and you can get the engine back alot further. Similarly if you use a wide tunnel with a type 9, you can still get the engine right back and have the gear lever in an acceptable position without using an extension. The narrow tunnel will always mean your engine is well forward, however there is more room in the footwell.
I'll tell you more about it on the Le Mans trip (If you can make yer mind up that is)
