completed jobs and list to do
So far in 2 weeks of ownership.
  1. LED rear lights
  2. Team Dynamics with Toyo proxy
  3. Removeable steering wheel boss (Sparco) (makes it sooo much easier to get in and out of)
  4. Re wire O/S headlight as previous owner cut the connector off the harness (what the devil why would anyone do that)
Left to do.
  1. Replace bonnet catches. The standard Westfield OE dont "lock" down and spring up. I guess they have been badly fitted. Purchased Aerocatch for the rear and a stainless latch for the front.
  2. Replace boot box. Previous owner cut the original into 3 pieces with strips of ally pop rivited and Dzus fasteners to remove a central panel above diff. Purchased a black one as new of ebay at the weekend (will be along another day for advice about measuring and cutting for the roll bar)
  3. At the same time as number 2 fit the 4 point harnesses as there isnt much room for me to get the seat belt done up.
  4. Ride height as per my other post
  5. Front and rear discs and pads Fronts being done on Saturday.
  6. Fit USB charger for phone for SATNAV
  7. Loose weight!!!
  • Like 4
Good work!
3 hours ago, Dave Eastwood (Gadgetman) - Club Secretary said:
Good work!
Thank you:yes:
I like the way you spaced your LED’s so the old holes don’t show.
Thanks, the reflector is covering the original hole where the cable for the original light came through
