Honda S2000 engine/supercharger parts/etc etc
Hi,
Due to a change in plans I have decided to sell my Honda S2000 engine along with extras. The engine is very low mileage (25000 miles). I have no proof of this except for the fact that I saw the engine in the rear end shunted 2005 car and was there when it was removed.  The engine was then soda blasted and painted silver to make it look nice and new. I also acquired a brand new rocker cover in the lovely unmarked crinkle red which I have fitted with new oem gaskets and seals.
I have removed the sump and had a baffle plate welded in. This is currently not refitted but I will do this using the genuine Honda sealant which I have also bought.
All of the ancillaries are included too which have been removed from the engine including starter motor, alternator, Flywheel, clutch, inlet manifold etc.
I am also including the following:
A brand new TTS bottom mounted supercharger kit which has all brackets, pulleys and belt.  I do NOT have the rotrex supercharger itself though. This was £810 inc vat.
Quaife S2000 to type 9 bell housing (long shaft I believe) £600
A spare damaged S2000 engine which I bought from my local Honda dealer. The car it was removed from had sucked in water from a flood. I believe it has bent the rods but can not confirm this. My plan was to build a 2.3 stroker engine out of it.
I am looking for £4750 for the lot.
Thanks. Tom
Hi, would you sell the damaged engine separately?
Craig
Craig
Hi. Yes I can do. Call me and make me an offer if you like - 07740948899
Hi Tom,
I am very interested in the shiny engine if it is still available? I'm in Western Australia though. Are we able to ship it over?
4 hours ago, Shane2me said:
Hi Tom,
Hi. Errrrrrrrrrrrrmm. Not so sure that’ll be possible I’m afraid unless you organise your own shipping! If it had been a set of brake pads then I could have done that but a 100kg engine !!!!??????
Thanks. Tom
