Westfield Se - 1986 Chassis no 013 No V5C This is a race / trackday project/hillclimb /sprint
•Prospeed full cage , side impact bars, harness bars improved chassis mounts. Integrated steering column mounts. ( The cage can be seen on the Prospeed-group web site). This is one of the best designed cages I have ever seen.
•Procomp rear adjustable link boxes, Link bars with rose jointed/poly bushed link bars, Panhard rod, English axle with alloy caliper mounts and machine Halfshafts for discs
•Procomp Custom front wishbones with Caterham uprights /brakes/alloy hubs (Ford PCD) with heavy duty stub axles. Adjustable anti roll bar.
•Alloy single adjustable coil overs set of four
•Various miss matched body work - main tub scuttle, nose cone. all race quality only.
•Modified trans tunnel. Very wide with reduced passenger footwell. (See photo named underside)
•Floor mounted pedal box with bias bar brake set up and Hyd. clutch .
•Powered coated white, however the alloy panels and floor will need to be replaced with new the riveting is very poor.. The floors are available as a template.
Ex. T Tulie Channel Islands championship car. Still holds many of the hill records. We need the space! We can arrange deliver in the UK.
Neil 01738 550005
