WHAT the hell happened here then?
Some Amazeballs times here, never before have I seen so many 101's in one place, .... except the Matrix of course :o :o :o , did they put something in the water or something.
Well whatever it was, awesome results guys
3 Sisters (R17) - Results
Tigger the Amazed
A nice bit of smooth tarmac helped
Clearly made a big difference, so shouldn't this have been a new event without set target times?
Dave
Terry will be along and correct me if I'm wrong but when Loton ( I think)  was resurfaced a couple of years ago it was discussed and decided not to treat it as a new venue purely based on the resurfacing work alone,  so a president was set to some extent.
The venue and track layout hadn't changed  so therefore it is not a "new event" as such.
Its a question of how far do you go.
If for example half the track had been done or just one section on a fast bend and the rest not, at what point do we say it has to be treated as a new venue.
Clearly new records have been set on this occasion so probably the new surface had an influence but equally if it had rained and or/no records broken it's unlikely this would have been raised, as the new surface could have had a negative effect just as easily.
I wasn't there but I'm told the paddock is still rubbish a full of loose stones and debris if that's any consolation.
Mark
Totally agree with Mark and his comments
everyond has known the track was resurfaced and the Target Times were published at the start of the season
Thanks both :yes:
