Nosbod Posted June 13, 2018 Posted June 13, 2018 Just a quickie; one of my post IVA mods is the addition of a rear diffuser (which is in the garage collecting dust). Question is what method/means have people used to attach/mount theirs? Thanks in advance. Quote
TableLeg Posted June 13, 2018 Posted June 13, 2018 I seem to remember seeing one which had a piece of aluminium rivetted to the chassis at the from point of the diffuser. The front then slotted into the gap the backs were pins secured into the spare wheel carrier mounts, these passed through a hole on each side and secured with a quick pin. 1 Quote
Castlecroft Posted June 13, 2018 Posted June 13, 2018 Pics of how we have mounted ours... carbon diffuser to a megabusa... slotted rail at the front, rivnutted to the chassis, and at the rear a rivnut with bolt (don’t use bonnet pins as the fall out) , with rubber washers to take up any gap.. hope this helps.. 1 Quote
Nosbod Posted June 14, 2018 Author Posted June 14, 2018 17 hours ago, Ben (bunje) said: depends which body style FW or ZK FW body, and Westfield supplied diffuser. Quote
CraigHew Posted June 14, 2018 Posted June 14, 2018 lots of historical threads on here about mounting the diffuser. Try the search function...? Quote
Nosbod Posted June 14, 2018 Author Posted June 14, 2018 5 hours ago, CraigHew said: lots of historical threads on here about mounting the diffuser. Try the search function...? Thanks for the constructive help... I did try searching before posting this but with no fruitful results...I Would be happy to pointed in the direction of them though! Fortunately there are other helpful folk using this forum who aren't keyboard warriors ;-) Quote
CraigHew Posted June 14, 2018 Posted June 14, 2018 2 minutes ago, Nosbod said: Thanks for the constructive help... I did try searching before posting this but with no fruitful results...I Would be happy to pointed in the direction of them though! Fortunately there are other helpful folk using this forum who aren't keyboard warriors ;-) It certainly wasn't meant to be offensive, shame you took it that way. My point was there are numerous historical posts with detailed photos that may help you decide which is best for you rather than one or two limited replies.... Quote
Nosbod Posted June 14, 2018 Author Posted June 14, 2018 3 hours ago, CraigHew said: It certainly wasn't meant to be offensive, shame you took it that way. My point was there are numerous historical posts with detailed photos that may help you decide which is best for you rather than one or two limited replies.... Far from offended, made me chuckle more than anything. Maybe if you hadn't posted in such an obnoxious manner initially, you wouldn't have had to explain it second time around :-) Thanks to castlecroft for the photo's. 1 Quote
