2012 CBR1000RR Install parts
Hello all,
I've picked up a 2012 CBR1000RR (SC59) engine that I intend to stick in my Westy. I'm not exactly sure which years parts cross over, and I think some bits have been the same for longer than others, but from what I can work out some items from 2008 onwards will be compatible.
I've got an AB sump already but other than that I need everything else. Tentative list is as follows:
- Full set of sensors
- Airbox with injectors
- Throttle bodies with injectors and TPS
- Stator
- Fuel pump
- Weld-in fuel pump tank adaptor
- Manifold to fit front engined RWD install (round exhaust ports)
- Wiring loom
- ECU (HRC would be ideal but would consider standard)
- Reg / rec
- Sprocket / prop adaptor and crank bolt
- Ignition coils
- Power commander
- 3.54 English diff or CWP set
I'm in no rush for all of these items, engine will be going in over winter, but would rather help clear out your garage / shed if you have anything going spare than risk eBay :)
Cheers,
Adam
  • 1 month later...
Hi adam give andy a call at ab always got bits available ,
plus free advice
