VDO oil pressure and fuel gauges and senders
Hi,
I'm looking to replace some of the gauges on my XFlow SE with a proper VDO set (see pic below that shows unknown/unbranded existing gauges) as I'm getting a few readings I'm not confident are accurate when the car is running.
PARTS REQUIRED
  • VDO oil pressure gauge (5 bar) and matching sender (with warning light)
  • VDO water temp gauge and matching sender - [possibly already sourced but please shout if you have one in case it doesn't come off]
  • VDO fuel gauge and matching sender
Let me know what you have and how much you want for it posted.
Thanks,
Andy
Water temp gauge and sender sorted :)
  • 1 month later...
A little bump on this... still on the hunt for a VDO oil pressure/sender and fuel gauge/sender. Cheers.
  • 5 months later...
Still on the lookout for the above if anyone has any lying around. Thanks.
