Protatype Polycarbonate doors
That’s interesting, I keep thinking there’s got to be a better solution for the doors.
Will look forward to seeing how you get on.
My doors seem to flap around and I am potentially looking at an additional strap at the end of the door where it meets the wheelarch. By holding it in location, seems to prevent the flapping around I currently have. Just need to find some nylon strap and no, dont check ebay using that description if you have a weak heart !! :o
  • Haha 1
Maybe want to consider deleting your browser history there mister TJ!  :suspect: :oops: :d
  • Haha 1
Doors tested
Visibility 100%
Flapping, none
Wind, gone
Noise, 50% better
Wife, happy
Conclusion, result
Usual problem with polycarb is whilst tough as hell, it scratches dead easy :/
Your quite right, just need to be careful which will be a first.
Yeah, most commercial applications like visors, protective screens etc, have hard coatings to give scratch reisistance. I wonder if there’s any sort of diy usable equivalent?
1 hour ago, Terryathome said:
Doors tested
Visibility 100%
Flapping, none
Wind, gone
Noise, 50% better
Wife, happy
Conclusion, result
I would have thought that the fact your wind has stopped would have made the wife happy Terry :d
When my wife uses my laptop for bravissimo and the like and I get bra adds all over the screen ( my story and sticking to it !!) can cause a slight issue with blood pressure and romantic evening gestures ( usually get told no!)
Yes, browsing history is now capacitors that I needed for work :down: such a sad muppet as getting capacitors on the screen to buy.....................sigh..............
Oh and fixed the doors as found some strap and poppers and made a second door strap, so happy days as a free mod.:yes:
  • Haha 1
Perhaps that’s why it’s so much quieter in there too!
  • Haha 1
Try tempting her with a bra :oops:
Could potentially use 2K clear coat, it works a treat on headlights (which I think are polycarb too) where the coating has turned misty/yellow. A bit of fine grit wet/dry to remove the old coating, 2k clear coat and it's hard as nails again + UV protected :D
I have used both of these at work (never tried buying direct privately but I'm sure something is possible):
Precoated sheet:
http://www.peerless-coatings.co.uk/plastics-supply/protective-coating-polycarbonate/
Liquid Coating - Spray/Dip (S500 is most suitable, but does require primer and thermal cure)
http://www.exxene.com/core-products/hardcoats/
Interesting. I know something is possible; my opticians have it done for lenses, and most are just dipped in the various baths for the different coatings. (A gross simplification, I know,, but not actually having watched it done, I don't know the exact process, just that it's doable on a small scale).
