Nic Surry Posted May 17, 2018 Posted May 17, 2018 Never had oil in it ,Incorrect pipe size for the dry sump kit I have so surplus to requirements hose fittings are AN10 what you see is what you get adapters are to fit to Westfield wet sump see other add and it has Oil filter sandwich plate and an extra hose £100 plus postage Nic 07454804995
Nic Surry Posted May 23, 2018 Author Posted May 23, 2018 On 22/05/2018 at 12:23, Stephen W said: What length are the hoses? I will check and letvyou know
Nic Surry Posted May 24, 2018 Author Posted May 24, 2018 On 22/05/2018 at 12:23, Stephen W said: What length are the hoses? Hi the hoses are 155,133 and 106 cm long
