snowy892 Posted May 17, 2018 Posted May 17, 2018 Hi I'm looking to put DRL's (daytime running lighs) on my Westy, so they come on when the ignition is on. Do you guys use these controller units? As the wiring seems very simple... thanks. https://www.amazon.co.uk/dp/B01M26LND1/ref=asc_df_B01M26LND152570151/?tag=googshopuk-21&creative=22146&creativeASIN=B01M26LND1&linkCode=df0&hvadid=256035930454&hvpos=1o19&hvnetw=g&hvrand=16158221007894547102&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1007160&hvtargid=pla-299303942370# Quote
Thrustyjust Posted May 17, 2018 Posted May 17, 2018 Car builder solutions do some as well . Worth a look. Quote
TableLeg Posted May 17, 2018 Posted May 17, 2018 I just used a simple changeover relay. The coil operated by a side light feed and one side of the relay supplying the Drls. Quote
Andy (Sycho) Posted May 18, 2018 Posted May 18, 2018 I used a controller which works fine apart from the dimming, it makes the lights flicker. This may be just my DRL’s though, I just disconnect them for the MOT yesterday. Quote
Kingster Posted May 18, 2018 Posted May 18, 2018 46 minutes ago, Sycho said: disconnect them for the MOT Sounds like a plan Quote
BugMan Posted May 18, 2018 Posted May 18, 2018 Dave have some experience of DRL's, have a look at his build? Quote
McFrancis Posted May 19, 2018 Posted May 19, 2018 I recently used the same DRL controller. I kept all the wiring near the fuses on the scuttle, as I used one of the live feeds as the main 12v feed so that the lights came on with the lignition, and the feed from the side lights to dim the DLRs. Earthed it to the earth point behind the engine and finally cable tied the box to the chassis by the earth. I also used a connector block from the out wires to the DLRs so that I could easily disable them if I had any MOT issues. Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted May 19, 2018 Posted May 19, 2018 Have used a few different ones over the years, to great effect. There can occasionally be the odd compatibility issue between the led chips used in certain DRL's and the dimmer part. But that's one of those things that either works or doesn't, straight away, so you immediately know if you have a problem. (It seems less of an issue with the more recent DRL's, made in the last year or so.) Quote
