jeff oakley Posted May 14, 2018 Posted May 14, 2018 Hi All, Windows 10 wants to update as normal, but this time it is saying cannot as virus scan 8 needs to be uninstalled. Problem is I cannot see said program anywhere on PC. Any ideas? Thanks in advance Quote
jeff oakley Posted May 14, 2018 Author Posted May 14, 2018 I looked for that and there is nothing MacAfee. I even uninstalled Adobe as I read that it was sometimes stuck in there. Quote
Blatman Posted May 14, 2018 Posted May 14, 2018 Where have you looked for said "rogue" programme? Quote
jeff oakley Posted May 14, 2018 Author Posted May 14, 2018 I am not a computer wizard, far from it. I have looked in the list of programs that you can uninstall. I did a search for any MacAfee products or anything with Virus scan 8 in the search box and nothing comes up. The Windows update just keep saying it cannot update and presents the fix button. When clicked it then gives the message that Virus Scan 8 is in compatible to update and must be removed, click the remove button and it then says it has to be done manually. That is where I am sort of stuck. Quote
ci_newman Posted May 14, 2018 Posted May 14, 2018 https://kc.mcafee.com/corporate/index?page=content&id=KB52648 Any good to you? Quote
Lyonspride Posted May 15, 2018 Posted May 15, 2018 Sounds like you have used or installed a McAfee product and this got bundle in without your knowledge. We used McAfee at work and even after it was removed, it kept elements of itself on the PC, it was right ballache. Quote
Andy Banks Posted May 15, 2018 Posted May 15, 2018 I've always found Revo uninstaller to be a good tool for fully installing unwanted programs. Quote
Blatman Posted May 15, 2018 Posted May 15, 2018 4 hours ago, Andy Banks - Chairman said: I've always found Revo uninstaller to be a good tool for fully installing unwanted programs. I prefer CCleaner but no matter. I think what we are saying here is that Virus Scan 8 may have been installed and un-installed at some point but enough of it's entrails remain for it to cause problems. Both CCleaner and Revo uninstaller should be able to deal with those entrails (likely buried in the Registry somewhere) and allow you to proceed with the update. Quote
Stuart Posted May 15, 2018 Posted May 15, 2018 I use both. Revo won't do anything unless it finds it as a program. Which it likely won't if Windows hasn't. Ccleaner might help though Quote
geoffd Posted May 15, 2018 Posted May 15, 2018 You could try running Task Manager (just type this into the Cortana box), and see if the virus scan is in the list of startup programs. Mine looks like this If you find it in the list, you can disable it. Then restart your computer and see if you can do the update. Geoff Quote
Blatman Posted May 15, 2018 Posted May 15, 2018 I wouldn't restart the PC after disabling the programme in Task Manager. IF it is in there, and IF the troublesome programme is an anti-virus or security programme it is likely to be set to start with Windows, so a reboot will just bring it back to life. IF it is in task manager, disable it and try the update straight away. Quote
DamperMan Posted May 15, 2018 Posted May 15, 2018 Check if mciffy has a removal tool on their website. I had an issue having loaded normal AVG at work, realised my activation code would only work on the business edition. Removed the normal one in the normal way, Could not completely install the business one as there where remnants of the old one. Then could not remove the half installed business one either. I was so close to Doing an open window drop kick format! Quote
