Martin Aldred - Shows & Events Coordinator Posted May 12, 2018 Posted May 12, 2018 Looking for a Westfield heater pipe manifold like this : Alternatively a complete heater unit with manifold attached. W.H.Y ?
Nic Chase (NICO) - Shropshire & Mid-Wales AO Posted May 13, 2018 Posted May 13, 2018 Hi Martin How about this from CBS? https://www.carbuildersolutions.com/en/black-nylon-twin-15mm-bulkhead-connector-angled If you buy before Monday using code SHOWSAVE you save 10% and postage.
Martin Aldred - Shows & Events Coordinator Posted May 13, 2018 Author Posted May 13, 2018 Hi Nic Thank you i had thought about those as a better way of connecting through the bulk head. My heater pipe manifold is so rusty that the end came away when i removed the hose and both pipes are full of rust sediment, which i don't want to introduce to the new engine or radiator. So i need to replace the manifold
