New 175lb Springs. Coolant & Fuel system AN fittings.
Hi, what engine are the plugs for?
Various cars
  • Peugeot 206 Hatchback 1.4 i (1998 - ) 55kW
  • Peugeot 206 Hatchback 1.1 i (1998 - ) 44kW
  • Citroën Saxo Hatchback 1.1 X,SX (1996 - 2004) 44kW
  • Peugeot 106 Mk II 1.1 i (1996 - ) 44kW
  • BMW Z3 Convertible 1.9 (1995 - 2003) 103kW
  • BMW 5 Series Saloon 523 i (1995 - 2003) 125kW
  • Peugeot 106 Hatchback 1.1 (1991 - 1996) 44kW
  • Porsche Boxster Convertible 2.5 (1996 - 2004) 150kW
  • BMW 5 Series Saloon 528 i (1995 - 2003) 142kW
  • Citroën Xsara Hatchback 1.4 i (1997 - 2005) 55kW
But the specs of the plug are as follows:
Technical Information:
General:
  • Type: Resistor type
  • Thread Size: 14mm (9/16")
  • Hex Size: 16mm (5/8")
  • Reach: 19mm (3/4")
  • Gap: 0.9mm (0.04")
  • Thread Pitch: 1.25mm (1/16")
  • Height Standard: ISO
Centre Electrode:
  • Type: Standard
  • Material: Nickel
  • Size: 2.5mm (1/8")
  • Projection: Extended Projection
Ground Electrode:
  • Type: Standard
  • Material: Nickel
  • Electrode Count: 2
4 minutes ago, TableLeg said:
Various cars
General:
Centre Electrode:
  • Type: Standard
  • Material: Nickel
Ground Electrode:
  • Type: Standard
  • Material: Nickel
Ah ok, no good for me unfortunately. Thanks for the quick response!
I'd like the push button starter kit please. Can I collect from Stoneleigh on the Sunday?
Many thanks,
Gary.
Hi,
i’ll take The hub nut covers please.
10 minutes ago, Zetec1.6 said:
Hi,
You have PM.
I’ll take the spare wheel carrier please
will be at Stoneleigh first thing Monday or whereabouts in Suffolk are you
You will also require the support bar, that bonds behind the rear panel, to which the spare wheel is bolted. Without this the wheel carrier is unlikely to take the weight.
Absolutely, what Dave said.
One on mine is very scabby it will be a replacement&
You have pm.
Bump
  • 2 weeks later...
Bump
