Carbon NV Westfield carbon fibre half doors.. new
Carbon NV half doors.
New, still in box .... never fitted.
£150 .. They are £190 from carbon NV
Can bring to stoneleigh.. or post at cost
Hi Trevor
will they fit narrow body se ?
Hi am interested, can you tell me whether or not these are for a wide or narrow car? Thanks, Craig
26 minutes ago, John rusher said:
Hi Trevor
Hi John,   you have first refusal.
Craig,  I will contact you if John doesn't buy them.
Quote from carbon nv website  re fitting to a narrow body....
Designed to help limit buffeting at speed, these half doors weigh-in at approx. 350g and make a stylish and practical addition to your car. These work really well with our 'double-bubble' aeroscreen. Some trimming required to neatly fit on Narrow Westfield bodywork
hope this helps
If it helps, they just need 30mm or so trimming from the leading edge to fit a Narrow neatly as the tub is a touch shorter.
They could be mounted un-trimmed, however, but would overlap a bit more than usual at the scuttle.
Cheers for the info
John
