John Williams (Panda) - Joint Manchester AO Posted April 25, 2018 Posted April 25, 2018 A couple of years ago the SSOT came up with a set of objectives/rules, bearing this in mind then all other decisions should be measured by the objectives. • Make the competition simple. • Increase level of new competitors. • Sustain levels of existing competitors. • Keep the cost of ‘starting’ to compete as affordable as possible. • To make the competition sustainable. • Prioritise changes for the good of the organisation/speed series. We published this internally and have been using these as guidelines when we when making judgment calls for the Speed Series. Many Thanks John Williams 3 Quote
XTR2Turbo Posted April 25, 2018 Posted April 25, 2018 John How do you measure success for each of these objectives and what are the scores at the moment? David Quote
John Williams (Panda) - Joint Manchester AO Posted April 26, 2018 Author Posted April 26, 2018 David, i understand where you are going with most of these are unmeasurable as like an aim for sustainability. These should be seen as ideals. As for the numbers/statistic we are looking at entry lists, previous years and feedback etc, which is why the gurston thread is still very active. Cheers John Quote
Mark Stanton Posted April 26, 2018 Posted April 26, 2018 Lets not forget ........................ FUN and ENJOYMENT .................... those two words will increase numbers, will make it sustainable, will bring in badly needed fresh competitors etc and will make all the spread sheets a better read for everyone. 2 1 Quote
John Williams (Panda) - Joint Manchester AO Posted April 26, 2018 Author Posted April 26, 2018 @Mark Stanton - WSCC Sponsors and Promotions I think that should be in there! and at the top of the list Quote
