Compression tester for zetec
Well good news,  compression results passed on to  Dunnell all ok ,he mapped the ecu and was confident that all was well with the map and ruled out bore wash ,he told me to check the water temp sensor .He said this ,if faulty ,would send wrong info to the ecu possibly causing the rough running and missing on a cold start .
When I checked there was a loose connection so I sorted that and since then all ok on start up .As said previously there was a bit of stutter under load however as the sun was shining I took it for a blat today (2 and a half tanks worth) and all my car paranoia has gone it drove exceptionally well .
So all in all a great ending I’ve crimped a wire changed the plugs and the car is running spot on .
Steve
