Posted (edited)
For Sale £18,995 ono
Westfield SeI – Vauxhall 2-Litre (270Hp) - Competition Car*
*Please note that this car is not currently road registered/road legal
  • A highly competitive and light car in any speed, sprint or race series, with a serious kick of power
  • Proven car that holds the current under 2 litre Class record at Gurston Down (31.41 sec),and will be immediately competitive in any Speed series.
    Gurston Down Hillclimb Video: www.youtube.com/watch?v=FaSDkP9f6Xs
  • First in class and 13th overall at Brighton Speed Trials 2016
  • Numerous other 1st place trophies and awards over the last 4 years
  • The Engine has done less than 1 hr competition running since last rebuild
  • This Westfield could be converted by the new owners, to full race spec with minimal changes and/or made road legal if required
Facebook Page: www.facebook.com/westfieldforsale/
SPEC
  • Lightweight high grade T45 steel chassis, ultra lightweight fibre-glass bodywork.
  • All steel 2.0 Vauxhall Red Top (c20xe|) engine. by Tom New/New Techniques and dyno tested at 270 BHP with 8 injectors,
  • 2012: new cams and new wiring loom
  • DTA S-80 Pro ECU with full data logging, launch control and traction control
  • Alloy fuel tank, pump, filter and Goodridge hoses & fittings.
  • Quaife 4-speed alloy case gearbox with 60mph first gear (using 4.7 ratio differential) Rocket Box.
  • Strengthened and reinforced Diff mount to take the power on high grip hillclimb starts
  • Up-rated driveshafts (new westfiield type) to take the power on high grip hillclimb starts
  • Tran-X plate limited slip differential (English)
  • Wilwood Dynalite front calipers fitted to light weight alloy front uprights.
  • High quality rose joint suspension throughout.
  • Protech single-adjustable dampers. All wishbones powder coated.
  • Willans 6-point harness.
  • Custom made rear suspension allowing rear tracking with wheels fitted at normal ride height.
  • Full stainless Simpson dyno tested exhaust and silencer box.
  • Wheels are 8x13 on the front and 10.5 x 13 on the rear.
  • Car comes with 4 slick tyres/wheels and 4 wet tyres/wheels.
  • 2 sets of spare scrub slicks for testing
  • Spare prop shaft (new/unused)
  • FIA Registered roll cage
  • Newly resprayed and fitted nose cone to remove stone chips
  • 2 spare carbon fibre bonnets and scuttle (used)
Edited by Neal Masters
Price Reduced
Wow. What a spec. GLWTS
  • 2 weeks later...
Thank you Nick. If I had room I'd keep the car but alas, other projects loom!
  • 3 weeks later...
Forgot to mention: The Tran-X LSD has just been rebuilt by Tran-X.
  • 4 weeks later...
The car has been fitted with the later aero cycle wings in carbon, which can be seen on the last few photos above
Price Reduced
  • 2 weeks later...
UPDATE - Will split ROLLING CHASSIS/ENGINE upon receipt of deposit
