BugMan Posted March 9, 2018 Share Posted March 9, 2018 Ok, so moving forward with my body shell, and have the rear tub slotted into place, as I figured it was a good idea to get an idea of how things fit together etc. Found I had to bend the standard rear spare wheel carrier brackets out of the way with a big screwdriver and a hammer, may take advice I have had to cut them off later,as this is just a dry fit. Thanks I then pulled out the RH side as I want to get the position of the scuttle sorted out, and this seemed the easiest way as from what I can see the rear tub is the datum on the back panel on the rear of the seating compartment. RH side seems an easy fit, apart from it's fouling on the seat-belt (I assume that's what they are for) bolt studs on the back of the chassis. There is a bit of a cut-out pre-formed on the panel which looks like its a bit short, and just needs lengthening? Can anybody tell me if I've got this right, before I commit to making red dust? Quote Link to comment Share on other sites More sharing options...
Peter (Monty) Posted March 9, 2018 Share Posted March 9, 2018 Don't worry, you're on the right track This question came up somewhere else recently, I have an album of photos from when I did this step here: https://imgur.com/a/1wL5c Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted March 9, 2018 Share Posted March 9, 2018 @BugMan I've found the side panel datum dimensions I knew I had somewhere! From front face of chassis, to front edge of front locating block (which locates bonnet):- o/s - 953mm n/s - 923 As with any WF dimension, it's a guide not an absolute, but provides a starter for ten for side panel positioning. Might help with initial side panel positioning, for cutouts for bosses, but be prepared to have to shuffle them fore and aft, for final positioning. Quote Link to comment Share on other sites More sharing options...
Beaker_Bob Posted March 9, 2018 Share Posted March 9, 2018 @BugMan I can’t help much with the process as I didn’t build my car, but I have an FW sport and I’m not that far from you. If a looksee and measurements would help, then you are most welcome to come and have a look. I’m just over the hill in the outskirts of Halifax. Bob. Quote Link to comment Share on other sites More sharing options...
BugMan Posted March 10, 2018 Author Share Posted March 10, 2018 18 hours ago, AdgeC said: @BugMan I've found the side panel datum dimensions I knew I had somewhere! From front face of chassis, to front edge of front locating block (which locates bonnet):- o/s - 953mm n/s - 923 As with any WF dimension, it's a guide not an absolute, but provides a starter for ten for side panel positioning. Might help with initial side panel positioning, for cutouts for bosses, but be prepared to have to shuffle them fore and aft, for final positioning. Ok, having a bit of a fight with the shell, but have the rear tub in what looks like the right position, with both side panels on, although not clipped onto the bottom of the chassis. Your dimensions are spot-on AdgeC Next is the dreaded cut work on the scuttle, CAD to the rescue here. Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted March 10, 2018 Share Posted March 10, 2018 @BugMan You probably have, but just in case! Try putting the bonnet on, and see where every thing sits with that on, and nose offered up in place. Nose cone dictates spacing across side panels at the front. Ideally each side will be equal! But don't be suprised if you have to get it right by eye rather than ruler! Check clearance of front edge of o/s panel to lower wishbone. Had to "dress" my panel to give adequate clearance! Quote Link to comment Share on other sites More sharing options...
BugMan Posted March 10, 2018 Author Share Posted March 10, 2018 Yep, thanks that's what I'm working toward. Currently I cant believe how badly things line-up between the sides and rear tub, the gaps are all over th eplace, and can see why the idea is to olt it all together and then bend it to fit on the chassis Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted March 10, 2018 Share Posted March 10, 2018 Have you tried bolting the wheel arches on to see the full picture Quote Link to comment Share on other sites More sharing options...
BugMan Posted March 10, 2018 Author Share Posted March 10, 2018 Yea, and my mood got worse, so I stopped on that and started on my CAD scuttle 1 Quote Link to comment Share on other sites More sharing options...
