Clarification of Technical Specification of Road Going/Road Based Cars 2018
Clarification of Technical spec of cars 2018 1.2.pdf
In addition to the MSA requirements in Section J, S10, S112 and S123 the Speed Series Committee wish to clarify the technical specification requirements for cars running in classes A, B, C, D, E, F which are essentially Road based cars. In the spirit of our Regulations and in order to maintain parity of car specifications the following will apply.
  1. Classes A and B must be able to produce proof of current UK road tax, insurance and MOT (if age require it).
  2. Cars is Classes C, D, E, F and must have either the following road tax, insurance and MOT or alternately a vehicle passport.
  3. All cars must have a front and rear number plate (either a plate or stick on type)
  4. All cars must be fitted with front facing headlamps, taillights, and indicators
  5. All cars must be fitted with a suitable passenger seat (grp or foam cushions etc.) as well as seatbelts and they should be capable of safely carrying a passenger
For any further clarification/questions please contact SSOT via "Speed Series Hotline" forum.
Many Thanks
The SSOT
Produced 2nd March 2018
updated as it should be s11 and s12, not s12 and s13..... also includes j and s10
Sorry but Steve and I will have to withdraw from the championship for this year then as although our car is road legal and has an MOT, but due to work commitments we will be unable to fit lights for this year.
  • Sad 1
Roz
the lights are an easy fix
call me
07767836234
  • 9 months later...
9 hours ago, S2T said:
Regarding point 5 above ... All cars must be fitted with a suitable passenger seat (grp or foam cushions etc.) as well as seatbelts and they should be capable of safely carrying a passenger
will this comply https://www.scottsofstow.co.uk/sos/memory-foam-car-seat-cushion
Looks ok to me as long as you have belts on the passenger side as well
Could you pass an MOT with that type of thin memory foam cushion??? It looks like a kids booster made to fit on top of a normal seat. Would you be happy to blast around a track or the roads with your bum sat on that?????? I think you would end up black and blue.
If the answer is no then its inadequate IMHO
I've passengered and instructed in 'worse'! :laugh: Looks fine to me, too fancy if anything :p
maybe you have a well padded rear end Adam:laugh:
  • Haha 1
I am not sure it would pass an MOT
We'll find out when my car is built I guess :t-up:
PS: you're right about my rear end.
  • Haha 1
@Martyn Vann - Joint Warwickshire AO could you give a view, on MOT and this seat?
IMO i dont think it would pass an mot - also other clauses that the blue book states which MAY also be relevant are below ---- but if in doubt then ask a scrute..... however, if you are really that desperate to save the weight then go on a diet ... its the cheapest weight saving option by far
Page 166 section k – competition safety
2.2. Seats. All seats should be correctly located and securely anchored in such a way as to allow no movement in squab or backrest
page 341 - Sprint and Hill Climb Vehicles
10.1.8. Road-Going Series Production and Road-Going Specialist Cars: front seats may be replaced by fully trimmed Competition versions
Basically seats have to be secure for the mot . The full manual is available online . Securing methods aren't specified so down to discretion of tester , the question your  tester would need to answer is how secure also bear in mind a 4pt+ seat belt holds driver or passenger sandwiching seat between occupant and body . All subjective really .
Why not Just MOT it with no passenger seat . Then stick that one in for competition
