Jerky acceleration
On the last couple of runs out I’ve notice that when accelerating sometimes it’s a bit jerky and not a smooth progression .This can be under gentle pressure on the pedal after lifting off .
its a tuned Dunnell zetec 2.0 blacktop and Ive had it for nearly a year now ,does it need fine tuning every now and then ?
Any thoughts
Steve
Could be the TPS (throttle position sensor).  Mine exhibited that sort of behaviour and it turned out that the TPS had come undone ever so slightly, so was giving false readings to the ECU at certain points.
Thanks Quinten is this something that can be checked easily (if so how) or does it mean a trip to a garage .
thanks
Steve
In this weather it’s probably just the wheels spinning! :)
Don't know which throttle bodies you have, but here you can see it on the Omex version
omex%20throttle%20bodies%20SS%20(1)_0.JP
it's the thingy on the left hand side.  It will have a electrical connector going to it.  Just check the screws first before spending money on a new one...
Edited to add: do not undo it!  It determines the amount of fuel going into the TBs, so if you undo it, you may need to hook it up to a laptop or (worse) have it set up again on a rolling road
Do you run it on normal 95 unleaded?
If you do try super unleaded 97/99 in it :)
Always have ,previous owner owner have same advice :yes:
worth checking Fuel Pressure too
Is it carbs or injection?
Jenevy throttle bodies
2.0 zetec
Sticky throttle cable? Cheap to swap out
I may have a similar problem, when I ease off my accelerator then just want to ease back on it can sometimes have kangaroo juice in it mine is a 1.8 zetec with injectors.
This is my first westie so still getting used to it
Bingo same symptoms as mine ,only happened to me recently,I’ve done a good 3000 miles trouble free up until now .
Im sure it’s nothing serious but looking for pointers as I want to understand the mechanical side ,if all else fails I’ll take it to a garage !
Your has throttle bodies where mine has injectors John asked if yours was Carbs or Injectors I’m wondering if he knows anything about the injectors that can cause me this problem it must be something or nothing because if I put my foot down a bit more it stops
Throttle bodies have injectors,just they have a individual throttle body for each cylinder rather than a inlet manifold with one big throttle body :)
