Panhard rods
Struggling to get these English diff panhard rods any ideas as can' get hold of pro comp
Mat at Procomp has just returned to work after being unwell for some weeks. He should now be able to answer calls 0121 350 3258
You surely only need one panhard rod? If you fitted 2 the suspension would be locked solid. Unless you have a watts linkage arrangement in which case you would have 2 lateral rods.
Any local engineering company should be able to make a pancake rod with relative ease.
All they are are two rose joints, a length of steel tube and a pair of threaded tube ends that need to be welded in such as these.
http://www.mcgillmotorsport.com/rod-end-accessories-imperial-sizes-weld-in-threaded-inserts-unf/
  • 2 weeks later...
Hi Mate
I have a complete set - all five - 4 trailing arms 1 panhard rod
Is that what you need?
I just got them all as spares - I destroyed a set getting them off and have already used 1 spare set:yes: - but if you are in need take them for what I paid £60
