Wanted - Type 9 input shaft nose cone
Seems like my assumption that I could use the input shaft nose from my type E for coming out for my type 9 going in was incorrect. :down: Should have looked into it a bit more.
Anyone have one or any ideas where to get one ...apart from Qaiffe/Burton @ £75 !!
Thnaks
Simon
19 minutes ago, wizzer said:
Good find. Could be, dont know part no. specifcally as I have'nt got one, not sure if there are many variants or just long and short.
In Israel as well, was hoping for something a little more local in case its not right !
I think I've still got one somewhere as I took it off when changing to a hydraulic clutch slave cylinder - anyone that has gone down the hydraulic clutch route may also have one spare. Can I just confirm that the part you want is part that the clutch release bearing slides on over the input shaft of the box?
Hi, Yep thats right also described as a gearbox front cover / clutch bearing tube. Sounds positive, I was hoping it could be something that someone had hanging around. Let me know if you find it and are happy to part with it.
14 minutes ago, wizzer said:
Thought they where all the same length , isn't it the shaft thats different size
This any good
https://www.bearingkits.co.uk/Ford-Sierra-Type-9-gearbox-front-cover-clutch-bearing-tube/674.htm
Yes could be, but the part numbers look to be 7050 BA which I think are long as I've seen a pic of the right one which has a part number of 7050 AA, but I could be wrong altogether. Could cut down if it is I suppose, but rather not. I'll give them a call as well.
Thanks for your help.
Im sure i have one of these kicking about. If you havent got sorted i will have a look for you
Have'nt got one sorted yet although possibilities are bubbling around, and I appreciate the responses so far..
I'll happily give money to the whoever can put one in the post for me.
Simon
Have a couple in the work shop, Pm with your address and i will send them - Neil  @ Areodynamix
YHM, thanks
Hi, I've got a spare bellhousing with the nose cone incorporated, it's not alloy so if weight is a concern it won't help much, but otherwise would be an ideal solution. Let me know if it's of any interest.
Barny
Hi Barney, its the box I bought from you that I'm putting in.....eventually (don't ask !!) :down:
Think I might have one from Neil (NDS), above, he is going to put one in the post for me. I have an alloy bellhousing so seems logical to retain that, but I will be in touch if that doesn't work out.
Simon
Hi Simon, no worries at all, I knew it was you who bought the box but wasn't sure if it was the same one! You'll love it once it's in ;) (said the actress to the bishop!! :laugh: )
If Neil can't help just give me a shout.
All the best
Barny
  • 2 weeks later...
Sorted :yes: thanks to neil @ Aerodynamix.
