SOLD, SOLD, SOLD, SOLD, SOLD, SOLD, SOLD, SOLD, SOLD, SOLD.
WESTFIELD SEI, X-FLOW,
RED
SWEPT WINGS
REGISTERED 1992
10,500 MILES FROM NEW
ONLY 2,500 MILES IN LAST 18 MONTHS
DRY WEATHER CAR,
TONNEAU COVER
FULL WEATHER GEAR, BUT IT IS NOT FITTED
MOT JUNE 2004
LAST 4 MOT CERTIFICATES
OWNED BY ME FOR 12 MONTHS
SPECIFICATION:
1.7 VULCAN X-FLOW
147 BHP, ROLLING ROAD TUNED
130 FT LBS TORQUE (APPROX)
711M ENGINE BLOCK
TYPE 9 5-SPEED BOX
FULL WEATHER GEAR
NEW SIDE SCREENS
KENT 244 CAM SHAFT
STEEL ROCKER POSTS
COSWORTH BOTTOM END BOLTS
FLOWED AND PORTED CYLINDER HEAD WITH MODIFIED VALVES
WEBER 40 DCOE’S (CORRECTLY MOUNTED)
ADJUSTABLE FUEL PRESSURE REGULATOR
NEW FUEL PUMP
NEW WATER PUMP AND COOLANT CHANGE
NEW ALTERNATOR AND BELT
BRAIDED FUEL HOSE (SYTEC STAINLESS)
K&N BOLT ON FILTERS (83MM), PROTRUDING THROUGH ENGINE COVER
SPLITFIRE TWIN CORE IGNITION LEAD SETDENSO “IRIDIUM POWER”SPARK PLUGS
4 BRANCH MANIFOLD
TECHCRAFT MOTORSPORT STAINLESS STEEL EXHAUST CAN
ARM-TECH REV LIMITER AND SHIFT LIGHTS (UP AND DOWN)
OIL CATCH TANK WITH LEVEL INDICATOR AND BREATHER FILTER
OIL AND FILTER CHANGED EVERY 2000 MILES USING GENUINE FORD FILTER AND MOTUL 15W40 OIL
VALVE CLEARANCES SET RECENTLY
SUSPENSION GEOMETRY FRONT AND REAR PROFESSIONALLY SET
CARBS PROFESSIONALLY SET UP AND BALANCED RECENTLY
RUN ON SUPER UNLEADED OR OPTIMAX WITH CASTROL VALVEMASTER PLUS ADDITIVE
SOME SILICON COOLANT PIPEWORK (BLUE)
WESTFIELD V8 WHEELS 15” (SET 5) SPARE NEVER USED ALL, PERFECT
NEW TOYO PROXES T1-S TYRES
LUKE 3 POINT HARNESSES
STANDARD INTERIOR, WESTFIELD 2-PIECE SEATS (NOT BENCH)
GREY SEATS, DASH, STEERING WHEEL AND CARPET
STANDARD WESTFIELD VDO GAUGES
SPAX ADJUSTABLE FRONT AND REAR SHOCKS
CHROME FRONT ARMS AND GRILL
5” HEADLAMPS
RECENT BRAKE SHOES AND CYLINDERS
STANDARD FRONT BRAKES, PLAIN FACE DISCS AND STANDARD PADS
WESTFIELD NYLON DIFF MOUNTING BUSHES
STONE GUARD FILM ON REAR ARCHES
FIREMASTER 1000 (1KG) EXTINGUISHER
RECENT WORK CARRIED OUT BY PROFESSIONAL & EXPERIENCED TECHNICIANS AT ABP MOTORSPORT.
RECEIPTS FILE FROM CURRENT AND LAST OWNER
£650.00 SPENT IN LAST 12 MONTHS,
NO EXPENSE SPARED ON THIS VEHICLE SINCE I HAVE OWNED IT, STUNNING VEHICLE IN A CLASSIC (SWEPT) SHAPE WITH BLISTERING PERFORMANCE FROM A GREAT 1.7 ENGINE.
MANY ADVERTS STATE THAT THE CAR IS IN “MINT” CONDITION, THIS VEHICLE IS AS CLOSE TO MINT FOR THE MILEAGE AND HAS BEEN PROPERLY MAINTAINED AND BUILT BY SPECIALISTS.
£6000 (VEHICLE IS NOW SOLD 01/02/2004)
CALL KIERAN ON: 07989 537092 (AFTER 6.00PM)
OR E-MAIL: kieranwesty@aol.com FOR FURTHER INFORMATION
(WSCC MEMBER)
  • 4 weeks later...
  • 3 weeks later...
Hiya Kieran
Is your westy still for sale?
My brother has caught the westy bug, and is planning on buying in jan/feb!
Danny
  • 1 month later...
Thanks for all the interest people,
The car is now sold and the lucky b****rd new owner has just collected it. Off to London for the Westy and i'm sad to see it go so what shall i replace it with........
so no more pointless replies just to get my car to the top of the list again.
Thanks again.
Kieran
