Wiring loom plugs Help
I have tried without success both on the forums and direct to WF ,I have a full Megabusa loom and need the dash loom or just the multipin plugs .someone must know where I can get this or have it for sale I am desperate now as car is nearly fully assembled but I need to sort the dash/ignition switch etc Help please Even a dash wiring diagram would help. Nic 07454894995
I will pm you a link to a wiring diagram it is old but relevant and easy to follow.
I'm not using the WF loom myself but if you put up some images of the connectors/plugs we could see if we recognise the type/make etc.
Which multipin plugs are you looking for?
These are the plugs I have on the main loom I need the opposite plugs for the dashboard loom or a complete dash loom it only needs to be a race loom as it’s a track day car with no wipers heater and using a Digi dash for the dials etc
Tableleg is spot on with that. A bit fiddly to assemble but work a treat when done.
Thank you for the responses I have located the plugs from the link and they’re
on their way.the wiring diagram will be a great help
:yes:
This is the standard chassis loom(attached). You may find these guides to colour codes etc help too:
http://www.mgb-stuff.org.uk/colourcodes.htm
http://www.expeditionlandrover.info/Lucaswirecode.htm
4833 Chassis Harness searchable txt.pdf
  • 2 weeks later...
Hi Thank you to those that supplied info does anyone have a wiring diagram for the Megabusa dashboard loom  race type preferred
