Weekend Warrior Posted December 21, 2017 Posted December 21, 2017 Was bored today so went into the garage and had a poke around the engine bay . I took the foam filter off the throttle bodies, for the first time and noticed there was more oil residue in the second trumpet . is this cause for concern ,if so why ? If not don’t wind me up as I know sod all about engines and worry enough already .Its a noticeable difference between the others but only just Quote
Thrustyjust Posted December 21, 2017 Posted December 21, 2017 You could buy a balancer or borrow if anyone local has one ? and just check that the balance is the same across the 4. If more air is going in that port, it could cause a light spit back . Nothing drama, but worth a go. http://www.burtonpower.com/catalogsearch/result/?q=balancer+weber 1 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 22, 2017 Posted December 22, 2017 slightly cheaper here: https://www.ebay.co.uk/itm/Dellorto-Weber-genuine-synchrometer-carb-balancer-made-in-Germany-not-China/290682796527?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Quote
