Sprinty Posted December 8, 2017 Posted December 8, 2017 Hi, I’m thinking of getting a Westfield but here’s the problem - my garage has been converted so it would have to sit outside (under a cover I guess) Am I totally crazy and would end up with a pile of dust or is it do-able? Thanks Quote
CraigHew Posted December 8, 2017 Posted December 8, 2017 Sure is, lots of people do it very sucessfully. In terms of covers, they range from an expensive, excellent pop-up garage type tent to very well made insulated, breathable covers. Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted December 8, 2017 Posted December 8, 2017 Keep it outside, pah, I built the last one outside! With a suitable cover, it's absolutely fine, just be aware of keeping on top of any preventative maintenance as far as rust etc goes. I use mine all year round anyway, so use products like ACF50 on the suspension parts come winter and salted roads. (Though I have been a bit tardy in this the year before last, due to other distractions). The main thing is if you get the interior soaked on a run, try and dry as much as possible before covering it back up again. Quote
DonPeffers Posted December 8, 2017 Posted December 8, 2017 What's the insurance angle of westie parked at home but outside? I know my insurance states must be garaged 10pm to 6am at home address. Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted December 8, 2017 Posted December 8, 2017 15 minutes ago, RussH said: Get an Elise No better/no worse! early ones at least, are little different to a kit car when it comes to how well they cope with being kept outside. (As told to me by a long standing Elise specialist). Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted December 8, 2017 Posted December 8, 2017 28 minutes ago, DonPeffers said: What's the insurance angle of westie parked at home but outside? I know my insurance states must be garaged 10pm to 6am at home address. Without wanting to state the obvious, that'll be because you've stated it's kept in a garage normally. It's not an uncommon clause on specialist policies, from what I can see. There doesn't seem to be a huge difference in premiums, if any, for my area, between stored on the drive, and stored in a garage. Funnily enough, I have a similar clause to your's but mine involves not keeping it parked on the road when at home. I do have to have an immobiliser fitted, but that's only because I happen to have an unusual set of insurance circumstances. (It's complicated and all to do with not having any "normal" car insurance for a daily driver - I have a pickup through the business on commercial insurance). Quote
Rory's Dad Posted December 8, 2017 Posted December 8, 2017 Read somewhere that a leaf blower is the thing to dry off your car! 1 Quote
darve Posted December 8, 2017 Posted December 8, 2017 45 minutes ago, Rory's Dad said: Read somewhere that a leaf blower is the thing to dry off your car! Given the other thread about using the dishwasher......... just use the wife's hairdryer...... Quote
Lyonspride Posted December 8, 2017 Posted December 8, 2017 The cover is important, it's got to be breathable and preferably not touching the ground. I had mine outside one winter after a house move and it made a right mess of it, most notably the carbs went from shiny/clean to covered in corrosion, brake discs, brake calliper pistons (siezed) and suspension parts corroded, took a lot of work to get right again. If I had to do it again, the cover would be supported off the car where possible, it would not touch the ground and I would rig some sort of ventilation system using PC fans, just to keep air moving under there to stop moisture attaching itself to the car and rotting anything. Quote
toys4x4boys Posted December 8, 2017 Posted December 8, 2017 I've never had a garage, nor had a car on SORN over winter. My Boxster lived outside for 4 years, much to the amusement of members of the Porsche owners club who kept theirs in heated air conditioned garages that would put my living room to shame ! The Westy will do the same. I've got a soft bits for sevens storm cap on it, over the half roof, and have the full side screen fitted. If it gets really wild out, I have a cheap nasty cover that can go over it. I also have a cheapo waterproof rucksack over the air filters, you can just see it poking out the bonnet in this pic ( yeah its colour coded yellow ) If it can't survive a few years outside without falling to bits, it'll be the last one I have. It's a car, made from parts that have survived since the 70's in some cases. The secrets are Use it, keep it outside by all means, but get it out and used, they rot outside because they aren't loved enough to be used Don't wrap it up too tight, you want airflow, not moisture build up. Oh, and after really heavy rain, the excess water runs out of the holes you will have drilled in the floor ! Quote
Mark (smokey mow) Posted December 8, 2017 Posted December 8, 2017 28 minutes ago, Lyonspride said: If I had to do it again, the cover would be supported off the car where possible, it would not touch the ground and I would rig some sort of ventilation system using PC fans, just to keep air moving under there to stop moisture attaching itself to the car and rotting anything. You've just described a Carcoon, which is what i'd be using if i had to store mine outside for any length of time. Quote
Geoffrey Carter (Buttercup) Posted December 8, 2017 Posted December 8, 2017 I have a Carcoon Veloce and its a great piece of kit. I dont use it outside though. Quote
Lyonspride Posted December 8, 2017 Posted December 8, 2017 3 hours ago, toys4x4boys said: I've never had a garage, nor had a car on SORN over winter. My Boxster lived outside for 4 years, much to the amusement of members of the Porsche owners club who kept theirs in heated air conditioned garages that would put my living room to shame ! The Westy will do the same. I've got a soft bits for sevens storm cap on it, over the half roof, and have the full side screen fitted. If it gets really wild out, I have a cheap nasty cover that can go over it. I also have a cheapo waterproof rucksack over the air filters, you can just see it poking out the bonnet in this pic ( yeah its colour coded yellow ) If it can't survive a few years outside without falling to bits, it'll be the last one I have. It's a car, made from parts that have survived since the 70's in some cases. The secrets are Use it, keep it outside by all means, but get it out and used, they rot outside because they aren't loved enough to be used Don't wrap it up too tight, you want airflow, not moisture build up. Oh, and after really heavy rain, the excess water runs out of the holes you will have drilled in the floor ! Your going to find that water gets in via the windscreen skuttle/bonnet gap, gets on top of the foot wells and then seeps into the foot wells themselves, which then pools and starts attacking things. Quote
