is this a fuel breather pipe???
Hi,
As the title suggests 'is this a fuel breather pipe'?
I noticed mine is split, does this matter? does it have to be a certain length?
thank you
Regards
Richard
Yes looks like a standard roller valve with rubber tube on outlet. This is normally tie wrapped to the roll over bar to best height you can get under the boot box
it was (is) but has split. should this be replaced?
I would replace it as is a very cheap repair
Thank you Terry.
Its on the list!!
Petrol vapour is heavier than air, so don't be tempted to vent it so far up you fill the boot box with a nice explosive combo.
