Derek182 Posted October 29, 2017 Posted October 29, 2017 Team Dynamics Pro Race 1.2 15 x 7 wheels in excellent condition except from some paint damage on the inside of 1 wheel from a snapped anti roll bar blade, just cosmetic and can't be seen once on car. Back space is roughly 135mm. Fitted with Yokohama AD08R 205/50 R15 86V nearly new, still got 6.5mm tread on centre grooves, 5mm on sides, guess that is about what they are when new. All balanced and ready to use, bought for my SEi, the rears fit perfectly but the fronts touch the wing stays so going to stick with 13" wheels. £450 Contact Derek on 07885 874031 or derekrogers33@gmail.com
Derek182 Posted November 3, 2017 Author Posted November 3, 2017 Price reduced to £400 before they go on eBay. Have had a bit more of a measure, appear to be about 35mm offset.
CraigHew Posted November 3, 2017 Posted November 3, 2017 Derek, The actual offset will be marked on the inside rim, as an e number, very hard to see tho. eg My rears in the photo below are e15
Wobblyprop Posted November 3, 2017 Posted November 3, 2017 Might be interested if you can tell me the offset for sure (it's stamped on the rims) and it's the same on all wheels. Where in the country are you?
Derek182 Posted November 4, 2017 Author Posted November 4, 2017 I've found the e number on the rim, they are all e35 offset. I'm in Chelmsford, Essex but do have relatives that fairly regularly travel here from Bristol and Exmoor so could get them to the Southwest.
