Vauxhall redtop 20XE engine parts
Redtop clearout:
I have lots of standard redtop 20XE and C20XE engine parts for sale, slowly sifting through all the bits I have and will post pictures up when I have got it all sorted out.
If any members want anything in particular let me know otherwise its all going on the usual auction site:
So far I have (all standard parts):
  • Cams - various
  • Sets of rods and pistons, some with arp rod bolts, some with standard bolts
  • standard cam pulleys
  • Sets of exhaust valves
  • sets of inlet valves
  • sets of valve springs
  • crank pulleys (TV dampers) poly vee belt type and early single V belt
  • oil dipstick tubes
  • camshaft covers (some modded with cover lip removed)
  • spark plug lead cover, there's at least one (plastic light weight vauxhall type)
  • thermostat housing with thermostats (various temps) some include the sensors
  • crankshaft sensors - the genuine OE Bosch ones
  • cam drive steel back covers
  • cam drive front aluminium covers
  • Mounting posts for the cam drive covers
+ lots of other bits still to find
Ping me a message if you want anything
Graham
What temperature thermostats in the housings do you have?
Pm sent
The ones I've found so far are both 92 degrees. I might have a 80? degree one somewhere.
Do u have a starter motor ??
I will leave it thanks as I found my spares I thought I had thrown out.  No I have a data logger I am experimenting to see what happens to temps on track.
Sorry I do have one but I need to keep it for a spare.
  • 3 weeks later...
PM sent
Crankshaft sensors sold
spark plug cover sold
  • 2 months later...
Graham,
Does the oil dipstick tube have a dip stick with it?
