jimbobtcc206 Posted September 27, 2017 Posted September 27, 2017 Hi guys, just wondering what sort of top end speeds average westies get to on the various tracks. I'm not talking the balls out 260bhp race engines but the mildly tuned track enthusiasts with cars affordable to the masses? Quote
TAFKARM Posted September 27, 2017 Posted September 27, 2017 Depends entirely on the track surely.....? 120 ish @ Bedford, but I tend not to be looking! Quote
jimbobtcc206 Posted September 27, 2017 Author Posted September 27, 2017 Yes absolutely it does. That's what I'm trying to understand. Blyton seemed to be c. 105 ish but Silverstone would obviously be a lot more (complete guess 120?). Just wondering what the ball park top end is for each track? Quote
Andrew Posted September 27, 2017 Posted September 27, 2017 My 170 bhp Pinto gets me to 120mph @ 7000rpm at Rockingham and Snetterton. Have not driven Silverstone, but 120 top end is more than enough for all other circuits I've done. Quote
AdamR Posted September 27, 2017 Posted September 27, 2017 Ballpark top end for each track is very dependent on driver, tyres, car spec, etc. I would say it's dictated more by these factors than the track itself, unless your car has loooads of power and is geared to the moon Mine will run into the limiter at ~118mph fairly easily with 'only' 185bhp due to low gearing, but it doesn't have a stupidly wide track at the front end, tiny headlights, aeroscreen and only a half cage. I've not driven this car on track much yet, but in the dry I expect to hit the limiter everywhere apart from Blyton. Quote
jimbobtcc206 Posted September 27, 2017 Author Posted September 27, 2017 Gearing is the reason I was thinking about this Adam. From a personal perspective it's pointless having a car geared to do 160+ as top gear is then just a waste and I'm not getting a car to drive around the road happily in 5th gear. Equally I wondered how short is too short. I thought maybe 135mph would be a good balance between not bouncing off the limiter and having gearing suited more to track than road. Quote
DamperMan Posted September 27, 2017 Posted September 27, 2017 115 seams to be about it on the flat. That's full screen. Massive headlights, full cage, 180bhP zetec. I was seeing about 110 at silverstone. It feels like it would do better with a gear between 4th and 5th. Quote
AdamR Posted September 27, 2017 Posted September 27, 2017 I getcha... and I agree entirely. Dropping gearing by, say, 10% is effectively giving you 10% more power by increasing torque at the hubs, and it's a damn sight cheaper than engine work usually. How much power do you have? What sort of bits are on the car? Quote
Dave Eastwood (Gadgetman) Posted September 27, 2017 Posted September 27, 2017 It depends how often you drive on roads I guess. Plus, if you do use on the road, how far do you go? If it’s only ever very short, local trips, then lack of a cruising fifth isn’t a problem so much. If on the other hand you like to head into Wales/Peaks etc and have to travel a bit to get there, sitting at high revs on a dual carriageway gets old fast. Then again, for tight twisty tracks, with more power, it’s not uncommon to gear long, and to be able to hit high road speeds in quite low gears. Exceeding sixty in first isn’t uncommon* and seventy/eighty in second. This means fewer gear changes on those slower bends, but also helps give so much “pull” out of the corners... While gearing short to make the most of lower power obviously has some advantages, again its a balance, if you’re forever changing gear, there comes a point when you’re loosing time. *having an engine that revs higher than standard, with a good power spread in those longer revs helps here, too. Quote
AndyD-Yellow Peril Posted September 27, 2017 Posted September 27, 2017 Gearing is the key, this is how mine is setup, with a 3.92 diff and 195/50 R15 (apologise the alignment is not the best), Duratec on TB's - approx 180bhp. Gearbox, best swap i did. SPC Tracsport type 9. Andy 2.482 1.61 1.225 1 0.82 RPM 1 2 3 4 5 1000 7 11 14 17 21 1500 10 16 21 26 31 2000 14 21 28 34 42 2500 17 27 35 43 52 3000 21 32 42 52 63 3500 24 37 49 60 73 4000 28 43 56 69 84 4500 31 48 63 77 94 5000 35 53 70 86 105 5500 38 59 77 95 115 6000 42 64 84 103 126 6500 45 69 91 112 136 7000 49 75 98 120 147 Quote
Terry Everall Posted September 28, 2017 Posted September 28, 2017 IMHO you need a lot of power to exceed 125 mph in a track Westfield even on slicks . Quote
SXRORY Posted September 28, 2017 Posted September 28, 2017 113 at Combe that's when the balls twitch and I have to have a dab before Avon rise. Im sure I could brake after but I like my car too much to find out. Quote
stephenh Posted September 28, 2017 Posted September 28, 2017 In my experience, it takes a lot of power to get a Westy much above 120 mph, in the real world, ie ignoring speedo readings, and following wind etc, and assuming a reasonable long but not ridiculous straight. They just don't have the aerodynamics. Quote
Nick Algar - Competition Secretary Posted September 28, 2017 Posted September 28, 2017 Standard Busa with aeroscreen will do about 130, very tuned Busa supercharged, the most I ever saw was 141 at Aintree and it was a pretty perfect day for it. Think Tommo's V8 would do about 150 there. Quote
Terry Everall Posted September 28, 2017 Posted September 28, 2017 My top spec blade in lightweight car just gets to 125mph and does not run out of revs ...it just won't go any faster Quote
