Badger56 Posted September 15, 2017 Posted September 15, 2017 Hi all, I have a 2004 Seight, my stearing is quite heavy at slower speads and I'm wondering if this is correct, I've seen videos of guys wipping the car about one handed and you'd need to be Geof Capes to do that in mine. Not sure about the rack but I'd assume its standard, I do have the wide front end. Your thoughts and advice would be very welcome. Cheers Quote
AdamR Posted September 15, 2017 Posted September 15, 2017 There are lots of variables - tyre type, tyre pressure, caster, camber, rack ratio, steering wheel size, condition of column bushes / UJs, etc. - but I'd hazard a guess at the big ol' engine up front is a part of what you're feeling! 1 Quote
John Loudon - Sponsorship Liaison Posted September 15, 2017 Posted September 15, 2017 How close do the steering column UJs go to the exhaust manifold? Heat could be making them stiff. Also worth checking that the front wishbones are on the correct way round to give the correct castor angle. You may laugh but I have seen this done Quote
andy665 Posted September 15, 2017 Posted September 15, 2017 Steering on my SEiGHT is very heavy at parking speeds but at anything above walking pace its absolutely fine and I'm nothing like Geoff Capes Quote
Badger56 Posted September 15, 2017 Author Posted September 15, 2017 Thanks all, I'll investigate further but yes it could be "the big ol' engine up front " :-) Quote
Steven Thorne Posted September 15, 2017 Posted September 15, 2017 Mine's very heavy a slow speeds but is fine when you get moving. Quote
Thrustyjust Posted September 15, 2017 Posted September 15, 2017 12 minutes ago, Steven (Steve T) - Joint Thames Valley AO said: Mine's very heavy a slow speeds but is fine when you get moving. Thats just the ******g big front spoiler that causes that 1 Quote
DonPeffers Posted September 15, 2017 Posted September 15, 2017 5 hours ago, Badger56 said: Hi all, I have a 2004 Seight, my stearing is quite heavy at slower speads and I'm wondering if this is correct, I've seen videos of guys wipping the car about one handed and you'd need to be Geof Capes to do that in mine. Not sure about the rack but I'd assume its standard, I do have the wide front end. Your thoughts and advice would be very welcome. Cheers If you can advise your front tyres width and also steering rack turns lock to lock we will have an idea of what you're up against. These days I'm more Frank Skinner than Geoff Capes and at 10mph I can whip the wheel round one handed provided I get my right thumb thru the steering wheel below the left hand spoke for a right turn IYSWIM. I have 195 tyres and 2.4 rack. Quote
Badger56 Posted September 15, 2017 Author Posted September 15, 2017 Just now, DonPeffers said: If you can advise your front tyres width and also steering rack turns lock to lock we will have an idea of what you're up against. These days I'm more Frank Skinner than Geoff Capes and at 10mph I can whip the wheel round one handed provided I get my right thumb thru the steering wheel below the left hand spoke for a right turn IYSWIM. I have 195 tyres and 2.4 rack. Ok & thanks, car not at home at the moment as I'm moving but will have a look over the weekend, the tyres are 17 inch low profile which could be part of the issue, it's not a "problem" as such but thought I'd ask, I'm going to splash out on a ProComp set up etc soon so maybe that will help. Cheers for all the replies as always. Quote
DonPeffers Posted September 15, 2017 Posted September 15, 2017 One thing that can make a rack stiffer is lack of lubrication on the steering column lower splines and black Graphite grease is recommended. Quote
Rory's Dad Posted September 15, 2017 Posted September 15, 2017 The stiffness of your low profile tyres won't be helping... Quote
Maurici- CleaR Motorsport Posted September 17, 2017 Posted September 17, 2017 mine is VERY hevy even with the front end in the air... And all has been revised and lubricated properly very recently. Once driving is Ok. in my case, even with the steering arms disconnected, wheel was fairly difficult to move around, so Top and bottom ball joints are the gilty in my car. Check that... but not much you can do in that case. My ball joints are brand new... Quote
Jonsey Posted September 19, 2017 Posted September 19, 2017 If steering still stiff with arms disconnected may be worth also looking for damage to the rack i.e. May be bent just a thought as race autocross with quick racks and any impact to wheels can cause damage to the rack that's why the guys run light weight steering arms so they bend before damaging the steering rack Quote
