O/s front upper and lower arms
Hi , looking for wide track upper and lower front arms o/s only required but would consider complete front set for a 2014 westfield and steering rack, if not available and have to buy new is there any difference between west field parts and rally design parts Appart from the price ? Thanks in advance .
You can't mix the two wide tracks, the arms are physically quite different.
Personally, I'd steer clear of the RD widetrack kit, too. They do many excellent products. And then they do that widetrack.
Thanks for the reply, when you say can't mix do you mean west field on one side and rd on the other ?
All or nothing. So all Westfield wide track, or all Rally Design wide track, or all Siltech widetrack for that matter.
They areant standard parts, so dimensions and proportions and even material specifications are just not standardised across any of them.
Also - there's different versions of Westfield's widetrack - so if you need to just replace one side, you need to know exactly which type you have in order to match them.
In terms of difference between the brands - it is generally accepted that Siltech are the top end and RD the bottom. Some have mentioned that the 'fit' of RD one's can be a bit off - but I guess they are a fraction of the price of the latest WF versions.
Also bear in mind what length shocks you have - as different sets of wishbones can use different length shocks.
The Siltech stuff can accommodate different shock lengths and has 3 different widths available I believe
Hi I have all the parts required now thanks for the replys
