b16gnr Posted September 10, 2017 Posted September 10, 2017 I am going to replace all the bulbs with LEDs but not sure where the flasher relay is I've looked everywhere under the dash but can only find these two any clues??? Quote
Kingster Posted September 10, 2017 Posted September 10, 2017 Those two look like ECU relays. The indicator one is usually by itself on the harness under the scuttle. Quote
b16gnr Posted September 10, 2017 Author Posted September 10, 2017 Thanks Chris I have had a look under the scuttle but can't seem to see anything Quote
TAFKARM Posted September 10, 2017 Posted September 10, 2017 Can you flick the indicators on and trace the noise? 3 Quote
CosKev Posted September 11, 2017 Posted September 11, 2017 As above, you can usually find them with the indicators on,even if it's in a row of two or three you can feel the contacts moving with the indicators on Quote
Terry Everall Posted September 11, 2017 Posted September 11, 2017 they usually make a loud clicking noise when on Quote
b16gnr Posted September 11, 2017 Author Posted September 11, 2017 thanks everybody i will try that tonight Quote
b16gnr Posted September 11, 2017 Author Posted September 11, 2017 I have found it, cunningly bolted to the back of the dash! 1 Quote
