Indicator swop
All I need to do is do something with the holes???
Fit a pair of carbon fibre canards - doesn't fill the holes but will hide them
It is quite common to cover the holes with mini air deflectors . Does nothing for aero, but you use the same holes drilled in the nose . Either that or cover the outside with polythene and fill the holes with fibre glass . Then flat and touch in with a colour.
Has anybody got any photos of the canards fitted covering the holes?
Thanks for that, l will probably go down that route
